Hello All:
My 1974 has developed a vibration between 50 and 60 mph. At 70 TO 75 mph it is much less severe but still there. Below 50 mph it is not noticeable. It feels like I'm driving over a washboard. I don't hear any excessive noise.
The tires have been balanced, new shocks, and a recent alignment. The Service manual states to check for rough rear wheel bearings, unbalanced or damaged propeller shaft, worn universal joint in propeller shaft, mis-indexed propeller shaft at companion flange, and excessive companion flange runout. I'm taking the car into the shop to have it checked out. Any thoughts and is there anything else should I have checked out?
I did notice that the rear wheels don't turn as easily as I remember. Last Fall I had the car serviced before storing it for the Winter, I'm wondering if the wheel bearings were tightened up. I checked the invoice and it doesn't say anything and I don't recall the mechanic mentioning it. I noticed the problem the first time I took the car out on the highway after the work was done.
Thanks, Bill
Thanks, Bill
