I rebuilt my 61 270HP engine during the frame off restoration process. The resistor that was on the engine was in very poor condition (many cracks) and I replaced it with an after market reproduction replacement resistor (. 3 ohm) which should be correct for the high performance engine. With this resistor the left set of points would burn out after a few hours of run time. After replacing three set of points, I replaced the resistor with an over the counter generic resistor (.8 to .9 ohm). I am still using this resistor at the current time and have about 500 miles on this resistor. I have just purchased an original GM# D111 1931385 resistor and would like to install it on the 1961. I measured the resistance and it is .3 ohm. Why would the original resistance specifications cause the points to burn with such short run time and what needs to be corrected to use the original resistor? The coil is an #091 coil.
Thanks Ray
#36314
Thanks Ray
#36314
