Shortly before the server decided to go into White Screen of Death mode, I posed a question about the missing automatic choke in my new (to me) '67 big block. Uncle Joe and Carl Rose were kind enough to respond (thanks guys), but due to the WSD, I was unable to ask a follow-up question. The number on the air horn of the carb is 4779-B or 4779-6, which, according to Holley's website, coincides with model 4150. Close examination of my AIM shows that the choke bell crank attaches to the throttle plate, which in turn attaches to the choke butterfly. According to the AIM, however, there should also be a vacuum assist, which likely has the function of pulling the choke butterfly open slightly after sufficient manifold vacuum is available. This vacuum assist is also missing. I realise this is a fairly prosaic problem, but can anyone give me an idea of what this is actually supposed to look like? Are these parts available or am I better off just installing a hand choke?
Thank you.
Bill Braun #33186
Thank you.
Bill Braun #33186
