66 Parking Brake Bracket - Hole - NCRS Discussion Boards
  • John L.
    • 409
    I have seen many 1966 parking brake brackets (where the parking brake handle mounts to the underside of the dash) with about a 3/4 inch hole in the upper left hand corner. I have also seen many without the hole. Could somebody please comment on this. Is this hole original ?? What was it used for - perhaps the hazard warning system ?? Which is correct hole or no hole. Thanks in advance.
    Re: 66 Parking Brake Bracket - Hole
    Yep, that's where the optional hazard warning flasher mounted...
    • John L.
      • 409
      Jack -- as always thanks for the response. The reason I am unsure is because my AIM describes the hole for the hazard warning switch as being drilled in the center of the bracket about 2 inches above the center of the handle. I cant think of anything else it could be used for and I have seen too many of them with the hole I mention to be made by the previous owner. This was a New York delivery car from day one so it would have had the hazard warning from the factory.
      • Wayne M.
        • March 1, 1980
        • 6414
        All have upper-left hole -- for the oil pressure..
        ...tube to pass through on its way to the gauge on the dash. Only the V74 cars have the hole in the center of the bracket.
        • ronnie robertson # 36786
          This was a convenient location for
          electrical switches. Use your imagination on what they controlled- 8 tracks, lights, reverbs, amps.
