C2 Heater Box Caulk - NCRS Discussion Boards
C2 Heater Box Caulk
  • Eugene B.
    • May 31, 1988
    • 710
    C2 Heater Box Caulk
    Members,
    When I disassembled the heater box for restoration I found an off-white caulk substance between the plate that holds the heater core and the fiberglass box. This caulk is also used to seal the heater core to the mounting plate. Car is a '65.
    What material can I use to replicate this factory caulk?
    Thanks in advance for all replies.
    Gene
  • Harry Sadlock
    Re: C2 Heater Box Caulk
    Gene, I have rebuilt 3 and have not seen any caulk or sealer anywhere. It may have been used by bubba on a prior rebuild.
    Harry
    • Dave Marshall
      Gene,
      I have my heater assembly apart on my '65 and I too have the caulking in the same places that you do. I just replaced it with some string caulking that I picked up at the local building supply store. Not much help, but that's all I have right now.
      Dave
      • Douglas L.
        • August 31, 2003
        • 299
        Gene,
        You might try some window bedding compound. Find it at LOWES or HOME DEPOT. Comes in a caulk tube. It's white and never hardens. I have used it for other applications and the stuff works pretty good.
        • Eugene B.
          • May 31, 1988
          • 710
          Doug,
          Thank you for responsing to my posting and the tip about window bedding compound. Sounds like exactly what I have in mind.
          My other choice was 3M strip caulk, but it is black in color and I would prefer a more authentic look.
          Gene
          • Larry L.
            • May 31, 1993
            • 101
            3M strip caulk comes in light gray. The heater box on my 65 had the same caulk in the heater box.
