1961 shifter - NCRS Discussion Boards
1961 shifter
  • Theodore K.
    • December 1, 1985
    • 214
    1961 shifter
    I am working on a 1961 with a 4 speed and the stock shifter is very loose. I can see looking down from above that the cross shaft is very sloppy. Has anyone had luck at rebuilding a shifter or is new replacement the only thing to do? The replacement price is quite high (approx $400).
    Comments appreciated.
    Ted
  • Chris H.
    • April 30, 1990
    • 817
    Re: 1961 shifter
    Mine was also very loose. I took it apart and replaced some of the parts that were very worn. Vette products has the individual parts. I replaced the shifter tower( the ball at the bottom was very worn $90) & the lower retainer which I think is the bent metal part that the tower ball rubs on ($17).
    I also bought the main shaft for $25 that they convinced me that I needed. I found when I used their part it froze the shifter up. They refused to take it back:( If you need one let me know.
    I also replaced the T return spring.
    chris
    • Theodore K.
      • December 1, 1985
      • 214
      Re: 1961 shifter
      Chris,
      Were you satisfied with the results of your rebuild? Do your have contact info for Vette Products? The main shaft is very loose. I don't know if it is worn or just the receiving end is worn. I will pull it tomorrow. I might need the main shaft. Please send me a private email to tvonkampen@charter.net so that I can communicate with you. It is good to find someone that has been there--Done that.
      Ted
      • William C.
        • May 31, 1975
        • 6037
        Re: 1961 shifter
        I just drilled out the shifter lever and crossshaft to accept the next larger diameter pin and improved mine substantially.
        Bill Clupper #618
