where is the heater control valve on a 71 LS5 with air? is this part still avalable from GM? if so how close is it to the oem one? who has a repop?
heater CV LS5
Re: heater CV LS5
lyndon-----
The water control valve for C-60-equipped cars is located on the right side firewall/fenderwell area, below the heater blower motor. The original valve used for 1971 applications was GM #3984642. That valve was discontinued 25 years ago and replaced by GM #3984641, the 68-70 valve. The 3984641 remains available to this day from GM.In Appreciation of John Hinckley- Top
Re: heater CV LS5
Lyndon if you have not removed the grille before the nut mounts to a stud made in the grille, so the grill will have to be tilted slightly at the top and lifted up until the stud clears. It a 7/16 nut and is located in kind of a recessed area towards the front of the side grille accessed from just in front of the body mount and the end of the splash pan. Knowing where mine are located and I can find them sitting beside the car a remove them with a long 1/4 inch extension. The nut is a star washer/nut combination piece on my 70. I installed a aftermarket coolant recovery tank on top of the splash shield using this access.- Top
