Actuator - NCRS Discussion Boards
Actuator
  • lyndon sharpton
    Actuator
    ok I put a vaccum on the actuator that I thought had a seal leak. when I took the open hose an pulled a vac it worked. then when I went to close it also it would work, so now where do I go to test the relay? how do you tell if the relay is working?
  • mike cobine
    Re: Actuator
    If you have Dr. Rebuild's catalog, you may find enough there to help. If not, go to this website:
    Tell him I sent you.
