This sheet concerns blower, evaporator and STV plumbing. My copy's print is very dense in lower left corner; can't read the torque references in the little triangles. I think the first line/triangle is a "3", but can't read the second line (also, is the torque range 23-28 lbs.ft ?), nor can I decipher the third line (first) triangle [I think the second triangle on the same line contains a "7"). The final line's triangle is completely black, on my copy.
TIA
TIA
