H20 Pump pulley for 69 SB - NCRS Discussion Boards
  • Brandon K.
    • April 1, 1997
    • 474
    I have a double-groove pulley with the number 1382533 ("SK" opposite to number), and I'm wondering if this will work for a 69 350/350 with a/c. the diameter of the part is 5 3/4". Thanks in advance!
    Brandon
    Re: H20 Pump pulley for 69 SB
    Brandon-----
    Let's put it this way: such a pulley was NEVER used for any 1969 Corvette application. In fact, it's not even a Chevrolet part number, so it was likely never even used on a Chevrolet. It's a Buick part number. Will it work? Well, the diameter is fairly close and it's got the right number of grooves. However, that's only part of the requirement. About the only way to tell, for sure, if it will work is through experimentation.
