63 radiator - NCRS Discussion Boards
63 radiator
  • jim cear
    63 radiator
    I have just tried to install my new repro radiator from Dewitts. The radiator that I'm replacing is also a correct repro with the correct part number and date code, however it appears to be brass/copper. (the car has Top Flighted twice with this radiator). It began to leak so I thought it would be a good time to upgrade to aluminum. The problem is that I could not get the top shroud bracket bolt holes to line up. It seem as if the Dewitts was a bit higher than the old rad. I measured the height of each core and found the Dewitts was 16 and 15/16th and the old one 16 and 10/16th, the Dewitts was over a 1/4 inch higher. My rad support looks original and unmolested as do all other components, and I confirmed that the radiator was properly seated with the proper rubber bumpers. Any ideas before I call Tom on Tues.? Thanks
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 63 radiator
    Jim - I have an aluminum randiator from Tom DeWitt for my 67 and since it is not installed (installed in the closet ) I just meaured it for you. It is 16 11/16" tall, basically 1/16" more than your brass copper. Not anyweres close to the extra 4/16" ( 1/4") you measure. Sounds like yours is too tall unless for 63 a different rad was used but I think all midyear small block rads were the same other than maybe the bracket on the top etc.....Craig
    • Craig S.
      • June 30, 1997
      • 2471
      Re: 63 radiator
      BTW - I have had this stored for about 4-5 years....so it is not his recent production runs....Craig
      • jim cear
        Re: 63 radiator
        Thanks Craig, sounds like I have a wrong/oversize unit for some reason. I was hoping to make it to a local charity car show on the 4th but thats history now. I have not found any records for any size variations for this part number. Again thanks so much for taking the time to check your unit. JIM
        • Wayne M.
          • March 1, 1980
          • 6414
          Two original rads measure 16-11/16", incl...
          ...top and bottom plates (maybe even add another 1/32nd). This is from a 65F and a 66M.
