c1 fuel line feeling hot - NCRS Discussion Boards
  • paul bowers
    in my 57 single four the steel line running from pump to carb. filter gets hot when car is running so hot that is difficult to keep my hand wrapped around it,
    it that o.k. some have said that if gas gets to hot, car may vapor lock and some have suggested placeing some type of rubber hose or else around this length of line, so should it get that hot and does degree of hottness bother anything thanks
    paul
  • Dick W.
    • 10483
    Re: c1 fuel line feeling hot
    Average person temperature of 110 deg or so is painful. If not vapor locking don't worry about it.
    Dick Whittington
    • paul bowers
      thats just it engine seems to just stop running all of a sudden, but mostly if i turn a corner onto a street it does restart again but only after cranking for awhile
      paul
      • Rob Dame
        Check the archives Paul. I think Clem or maybe Roy talked about the WCFBs doing this on a R/H turn. Something about the gas getting into the choke tube or ???
        Rob
