Hello all,
As promised, a little update on the project.
To review, we have a 1966 never-run block, that unfortunately had a cylinder scored by a student in shop class 30 years ago. It is presently undergoing an .030 overbore, but otherwise is stock 2-bolt. The induction is 1965 off-the-shelf fuel injection unit and intake. The exhaust manifolds will be 2.5 inch new GM castings, with 2.5 inch exhaust leading to Under-the-car sidepipe-style mufflers. Exit will be ahead of the rear wheel of our 1960 Corvette.
To date, we have the pistons (hypereutectic SpeedPro H660, flat top with 2 valve reliefs), as well as all ARP fasteners, FelPro Performance gaskets, and Clevite77 bearings.
On order is a FederalMogul retrofit roller cam, lifters and pushrods, part 1070R with 210/215 duration and .462/.470 lift, with 110 degree lobe separation.
Our latest question is regarding cylinder heads. We wish to use an aluminum head with 64cc chambers, which should give us good compression as well as heat management. Exhaust crossover is not necessary as the fuel unit doesn't need one. Possibilities include Trick Flow, Edelbrock Performer RPM, or possibly Airflow Research. Some investigating reveals through other discussion boards that the Trick Flows do not enjoy a stellar quality reputation. The Edelbrocks seem to be without complaint especially for a street motor. The Airflows are very good, but also quite expensive when compared to the other two.
Does anyone have any further thoughts or experiences with any of these heads? Recommendations? You may write to me off-board if you don't wish to make your comments known.
Also, any thoughts on aluminum water pumps? As long as we're using so much aluminum, we thought this was a natural too.
Thanks for the assistance.
Patrick Hulst
Patrick Hulst
