C2 4 speed shifter ID.. - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Looks like the old hurst has to go.... Need those points!
    How do you ID 63, vs 64-67, vs C3 4 sp shifters?
    Do the LICS and other vendors carry gudgeable repros or are they still GM sourced?
  • Harry Sadlock
    Re: C2 4 speed shifter ID..
    Jim, most of the major parts houses have 63 shifters and linkage. Expect to pay about $475.00 for both. Originals that need rebuild/refurbish are equally as expansive.
    Harry
    38513
    • Jim V.
      • November 1, 1991
      • 587
      Thanks Harry...but..
      If you attempt to find an original, how can you ID the diff between 63, 64-67, etc...
      Looks like LICS lists shifter, linkage, and shaft for about that....
      JimV #20146
      • mike cobine
        Re: Thanks Harry...but..
        That is easy. Here is a shifter set up for 1959 to 1962. It is almost the same as the '63 but the outside lever is too long, as it will hit the frame.
        The '63 looks the same but with a short outside lever. The outside short lever is NOT the same as the inside short lever, which will sit in the neutral position at the wrong front-back angle.
        Here is a '63. Note the different lever. Many try to sell the early one as for '63.
        The '64 to '67 shifter is very different, the most obvious is the thick straight chrome lever.
        You mentioned having a Hurst. Do you have a real Corvette Hurst or a generic Hurst. Many have been selling this type as a Corvette Hurst, but this has the welded in shift lever. This is the Falcon/Mustang Hurst. Corvette had the 7 inch bolt-in handle. This one is the Falcon, sold as Corvette:
        It fits, but the handle is too tall.
        • mike cobine
          Oops, the picture is 1963 - forgot to mention *NM*
          • Jim T.
            • March 1, 1993
            • 5351
            Jim a new 63 shifter is available from www.volvette.com for less than $400 and free shipping.
            • Jim S.
              • March 1, 1986
              • 1392
              Seems like a good deal?
              Mike ,
              Whats wrong with the Ebay 63-67 shifter you posted? Why are they priced so low?
              Jim
              • mike cobine
                Re: Seems like a good deal?
                Which shifter? The Hurst is a Falcon, with the welded in handle.
                The Corvette factory shifters will go nuts in the last few minutes of the auction. I've seen several that are low for 7 days and then sell of outrageous amounts.
                • Jim S.
                  • March 1, 1986
                  • 1392
                  Mike,
                  The 63-67 one on Ebay . It says he has ten of them and there is no time limit.
                  All are priced at $189. So why so cheap if you and other have stated they should be $400 plus ?
                  Jim
                  • Jim S.
                    • March 1, 1986
                    • 1392
                    Oh ! I see those are 64-67 ! I'm guessing they're cheaper than a 63 shifter !
                    NEVER MIND !
                    Jim
                    • Jim V.
                      • November 1, 1991
                      • 587
                      Great post Mike!...
                      What does the 68+ look like?
                      Can you tell me if the ebay 64-67 is repro..or is GM still making them?
                      JimV
                      • Jim S.
                        • September 30, 2003
                        • 77
                        Mike
                        I have bought several new Hurst Shifters in the late 60's and early 70"s for both c-2 and c-3 Corvettes. All had the welded on handles and were complete with linkage for the muncie. I didn't think the bolt on handles were available until the mid to late 70's
                        • mike cobine
                          I had a '67 in '74 that had a Hurst in it from sometime before that. It was a bolt in handle and it was the straight 7 inch stick. Most of these on eBay have this curved stick that is around 10 or 12 inches tall.
                          • mike cobine
                            Here is a link to a '69 shifter. I think '68 was the same, but I don't feel like crawling under mine right now to check. (actually, I don't feel like crawling under mine, period, but that will change when I get back to work on it.)
                            I don't know if the '64-'67 being sold is a repro or not.
                            The picture is a '68 - '76 according to the auction, and I'm not sure if there were changes. One change is that the '69 up had an interlock cable from the steering column to lock it in gear, but I can't remember how it hooked up down there or if the shifter was different or not as a result.
                            1968
                            1969 shifter - picture is a '68-'76
                            • Jim S.
                              • 77
                              Interesting, A 10 to 12 " stick would definitely be too long. The Hurst comp+ I bought in 1970 and installed in my 66 had about a 7" curved welded on handle. It was about the same height as the original. I used this shifter for 10 to 12 years and loved it. Finally reinstalled the original shifter just to put vehicle back to original.
                              I also bought a new hurst for my brothers 69 in about 1972 but it had a straight handle and it hit the console in 1st and 3rd. It also had a welded on handle. He still has the car with the shifter in it.
                              Who knows?
