Ok, my car is still running poorly and can barely pull its own weight before it dies. 1st it was reported we had "bad" (water) gas on the base over here in the U.K. I originally changed the carb from an otc 3810 to my totally restored 3810 721 dated for car and no change whatsoever. I then managed to get the car to stumble home where I drained the gas tank & the float bowls thinking that gas was the problem. Again test drive showed no acceleration, backfire etc. When I took it to an automotive shop here it was found that my distributor had came loose. I swear I never touched this!!! Anyway the mechanic who I have full confidence in set the timing to 10 deg. like my book says. The car idles beautifully but a test drive shows the car still stumbling, pop through the carb (now I just blew out my power brake check valve) and if I am lucky I can feather the gas peddle and get to 3500 rpm in 1st gear max. The car surges, shakes, etc. Does anyone have any ideas? My mechanic is thinking possibly my coil (original 202 still in the car) is having a problem. What about timing is 10 deg. to much? My engine is 100% stock. When I had it rebuilt I used a NOS Chevrolet 350 hp 67 cam, TRW 10.5 pistons with the exact dome as the originals however we did bore the block 30 over and did a 3 angle valve job w/hardened seats. This car was running beautiful now a 53/54 could beat me!!!
Suggestions please!!!
Thanks for your help in advance. We got sun here today and I am missing out!!!
