master cylinder leak - NCRS Discussion Boards
  • John O.
    • May 31, 1998
    • 480
    Hi All
    I have a master cylinder I just rebuilt for my 62 vette. The problem i'm having is a tiny leak at the bottom of where the large threaded end that holds the guts in. The large copper washer is smooth when I installed it. It still has a tiny leak. I tried the steel washer that came in the kit. Still has leak. I looked over the entire end and can't see or feel any imperfection. Is there something I could put on the threads that would seal it? Or should I not put anything on the threads? Any suggestions? Anyone know where I can buy a new copper washer? I saw in the corvette central book that they sell one, but it is for 53- 60 only.Wouldn't that also fit 61 - 62 ? I feel the copper would be better cause it's softer and thats what came with the master cylinder when I bought it.
    Thanks...........John
  • Rob Dame
    Re: master cylinder leak
    When i rebuilt the one for a 56 i had the same leak. I gave the nut a couple of very quick zaps with an air gun. That fixed the leak. Rob
    • Pierre J.
      • July 31, 2000
      • 193
      Re: 1972 Corvette Master Cylinder
      John,
      Also had the same problem with the copper washers on the M/C of my '56. I covered all the copper washers with a small coat of liquid teflon before install and the problem was fixed.
      Pierre
      • John O.
        • May 31, 1998
        • 480
        THanks Rob and Pierre
        I'll try tightening it more first, then the liquid teflon if that does not work.
        Thanks again..................John
