The '67 Assembly Instruction Manual shows that the odometer reset knob is attached with a nut to the pedal assembly support to the LEFT of the steering column. There is a bracket there that will accomodate the cable. However, when I mounted it there the cable is stretched very tight and the knob is in conflict with the hood release handle. There is a revision in the AIM saying the drawing was revised but it doesn't show what was revised.
The '67 owners manual states the the odometer reset knob is located at the bottom of the dash to the RIGHT of the steering column and it has a illustration showing the location. All of the vendor's catalogs also show the knob to the right of the column, except I can't see anywhere on my car to mount it. The '67 Judging Manual doesn't say where it should be located.
My question is where is the '67 odometer reset knob located or where should it go? Thanks in advance. PT
