If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I replaced my 1967 427-435 tri-power gas lines two years ago with no leaks and everything was just fine, I start and run my car every week, recently I have developed a small leak but it stops after it warms up. Today I drove the car for 2 miles and smelled gas and pulled over, when I raise the hood the car burst into flames. Luckily I had my fire extinguisher and dowsed the fire.
Question: Is there a procedure to install and tighten the tri-power lines?
to take all the lines and tighten the flares firmly into a spare steel fitting held in a bench vise to form the flare seat. the brass fitting are too soft to make a good fit on the steel lines and if your lines are stainless steel not carbon steel this MUST be done to get a good seal
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
