All,
At a point in the restoration of my '66 BB convertible of installing my rebuilt trailing arms. I have no information on the number/orientation of the shims that were originally install. I plan on using the original type (closed hole) shims. How do I get started?
I have searched the archive, with no success.
What would be the correct step-by-step procedure for initial installation/orientation of the shims? Even distribution of shims on each side of the trailing arm between the frame rails? Or does it matter? What direction do the tails of the shims (the ends not threaded throught the frame bolt) face? Are the tails of the shims connected in some fashion. I understand that adjustments will be made down the road when I have the vehicle aligned.
If some one could post some pictures of a correct installation it would be greatly appreciated.
As always a million thanks for your help.
Triple R
Triple R
