hello all
my temp gauge reads to much
when the engine is at approx 180 degrees the gauge says the max 220 degrees
i have read a post once, that its possible to adjust this with a variable resistor
but at what ohm range type resistor do i need ?
so i can buy one at the local shop (over here in the netherlands)
thank you Sander,
thank you Sander,
