1960 c1 temp gauge
  • Sander B.
    • March 1, 2005
    • 499
    1960 c1 temp gauge
    hello all
    my temp gauge reads to much
    when the engine is at approx 180 degrees the gauge says the max 220 degrees
    i have read a post once, that its possible to adjust this with a variable resistor
    but at what ohm range type resistor do i need ?
    so i can buy one at the local shop (over here in the netherlands)
    thank you Sander,
  • Michael K.
    • September 1, 2004
    • 170
    Re: 1960 c1 temp gauge
    Try Corvette Central. They have a resistor available. There are alot of problems with the new senders.
    • Mike Przano
      Sander,
      A 22ohm, 1/2 watt resistor should do the trick.
      Mike
      • Sander B.
        • March 1, 2005
        • 499
        I bought a Wells TU-5 on ebay last week will first check how that works out
        thank you anyway
        Sander,
