66 427, air valve covers?? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    I have a 66 427 with factory air. I have seen some valve covers with an indent on the front edge by the compressor mounting. Was this on all cars? Should I be looking for a correct set of covers or just the right side?/?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 66 427, air valve covers??
    Bill - this was a mid year production change. From what I understand, somewhere around November 65 and prior the AC dent was in the right cover. After this change, the covers and not dimpled. All cars got the cover, whether they has C60 or not. Expect to pay BIG dollars for a set whith the dimple....Craig
    • William B.
      • April 30, 1975
      • 939
      My car was built around dec. 22 1965 (66 car) so it would have been without the indent even with the air. Correct?
      • mike mccagh
        late dec 65 build date c-60 valve cover indent could go either way. mike
        • John L.
          • 409
          I have a Dec 17, 1965 (approx) 427/425 and it has both the dimple and the flat spot for the power brake booster.
          • William B.
            • April 30, 1975
            • 939
            If a late dec car could go either way mine on the judging field would not be hit with a deduct?
            • Craig S.
              • June 30, 1997
              • 2471
              Interesting thread...... I would go with Mike's advice unless you want to spend upwards of $1k for valve covers......
