C2 67 wiring plastic T-Straps - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3148
    How can you tell if the plastic T-Straps that hold the wiring in place under the hood of a 67 are correct? Are there some identifying marks on them or on the aftermarket straps that distinguish between the straps?
  • Geoff C.
    • May 31, 1979
    • 1613
    • Stephen L.
      • May 31, 1984
      • 3148
      Re: C2 67 wiring plastic T-Straps
      Thanks for the in-depth response. I won't be able to go to Carlisle.
      • Rob A.
        • December 1, 1991
        • 2126
        Steve,
        I know that all the repros I found for the ones that held the wiring in place along the innner fenders did not fit tightly in the holes, as did the originals . I found some used ones still attached to an old wiring harness to use. The originals seemed more soft and pliable, even as old as they were, than the repros.
