Ouestion on a 70 wiper motor number - NCRS Discussion Boards
  • Steve D.
    • May 16, 2011
    • 106
    What are the correct numbers. Mine is 4939300.
    Steve
  • D S.
    • March 1, 2005
    • 1551
    Re: Ouestion on a 70 wiper motor number
    Somewhere I found a number of 4914569 for the '70 wiper motor. I have been known to be wrong but I have it in my parts list use at swap meets. There is a seller on eBay by the name of dt32degree that rebuilds Corvette wiper pumps/motors that should know.
    Scott
    • Gary S.
      • July 31, 1992
      • 1628
      I don't have my 70-72 judging manual but I remember it had the wiper motor information in the appropriate section. If you don't have a judging manual, they are available at this online store and are an extrememly valuable aid for anyone.
      Gary
      • Chuck S.
        • April 1, 1992
        • 4668
        Where did you read this number? Wiper motor assemblies had higher part numbers, i.e. 5XXXXXX, way back in the C1 years. I believe you could be looking at a wiper motor component part number, casting number, etc. That number does not show in the part catalog I have, which could mean it's not serviced separately.
        The wiper motor assembly part number will be on a silver foil label on the motor housing. This label will also show the build date of the wiper motor assembly. The 70 Assembly Instruction Manual (late) shows the wiper motor assembly number as 5044758. A secondary collaborating source is Paragon's repro part number label. If yer not going to buy the AIM, then at least order some vendor catalogs...cost is minimal.
