c1 cooling fan swap - NCRS Discussion Boards
c1 cooling fan swap
  • don izzo
    c1 cooling fan swap
    I have been thinking of swapping out the stock cooling fan (4 blade,no clutch) in my 60 for a 5 blade (no clutch). I feel this will aid in the cooling of the engine which has a tendance to run a bit hot on hot sunny days.
    can anyone suggest a replacement fan that will fit inside the shroud and work with the stock spacer that I might be able to purchase say from my local junk yard? Or what else is out there I can consider?
    thaks to all!
    Don
  • Kent D.
    • February 1, 1992
    • 100
    Re: c1 cooling fan swap
    How about a 5 blade fan with the clutch. You should be able to find this set up in a junk yard from a lot of early '60's GM cars.
