I have an original, 67-dated big block Schwitzer (bar-type) fan clutch that unfortunately, was stored face-down causing the fluid to leak out of the front plunger. Referencing "Fan Clutch Cool Down" (Restorer Winter 1991) and "Corvette Fan Clutches" (Restorer Spring 2005), it would seem that you could refill the reservoir by removing the rectangular bimetallic plate and brass actuator plug, depressing the valve and refilling the reservior with a high quality silicone hydraulic fan clutch fluid (Toyota Part number 08816-03001). A variation of this procedure is well known for the sealed Porsche 928 fan clutch. See http://www.nichols.nu/tip482.htm
Has anyone ever tried this?
