Leaf Spring dimension - NCRS Discussion Boards
  • Howard M.
    • June 30, 2000
    • 124
    I'm trying to determine the wellness of the leaf springs on my 60. If I put a straight edge on the eye to eye centerline across the spring, what is the dimension with acceptable tolerance, to the top of the first concave leaf. If I have to have the spring rearched, the spring refurbisher also needs this dimension. This is with spring off the car.
    Thanks.
  • Richard E.
    • November 1, 1976
    • 200
    Re: Leaf Spring dimension
    Howard- Lots of related stuff in the archives. A post by Dale Pearman on 8 November 2001, addresses these dimensions. If you think re-arching is needed, the OEM Spring Mfgr, Eaton Springs in Michigan, has all the dimensions and can do it for you. Regards....Dick
    • Howard M.
      • June 30, 2000
      • 124
      Dick:
      Thank you-I found it! Exactly what I needed.
