I converted my 66 roadster w/AC to 134 late in 2003 . Conversion included virtually everything rebuilt or changed including STV valve. Only the evaporator wasn't changed but was blown out to be sure no obstructions. I ran the system all of 2004 obtaining high 40 deg temps. Spring 2005 the ceramic shaft seal on A6 comp failed (rebuilt in 2003). Replaced seal and recharged the system today, a high humidity 93 deg day in Atlanta. AC Shop used 2.5 # R134a ( R12 capacity is 3# 4 oz)
The best we could get today was 60 deg temps at outlet vents with top and windows up and shop fan blowing on condensor. High side pressure was as high as 350psi at 2000 rpm and low side was 35-37 psi. Shop re evacuated and recharged hoping there may have been an air bubble but no significant changes.
What are we missing??
Randy
Randy
