72 trim rings - NCRS Discussion Boards
72 trim rings
  • Melissa N.
    • March 1, 2003
    • 41
    72 trim rings
    Other than placement of the clips is there any other difference the judges will be looking for regarding the difference between original and repro trim rings?
    Thanks..........
  • lyndon sharpton
    Re: 72 trim rings
    I think the lip is not the same on some repros, do you have a original? look at them side by side an you will see what I mean.
    • Sal C.
      • December 1, 1984
      • 430
      Re: 72 trim rings
      The inner ring that holds the retaining clips in place will be flat at least through 1973. Some time after that this ring received a "lip" edge fo strength. These inner rings have been seen either painted black or natural finish. I have been told that original 1967s (6 inch rings) had the black inner rings so I can only assume that the earlier 7 and/or 8 inch were finished as such. Wouldn't really matter though as this can't be seen while installed. The "lip", however can be easily detected by the insertion of a credit card between the wheel and trim ring.
