Antenna cable conntinunity - NCRS Discussion Boards
  • James F.
    • December 1, 1985
    • 596
    While back I learned from Jack Humphries (on this board) why the antenna centerpost does not have continunity. I didn't understand it(he does) but the Radio Shack cable (no continunity) did work on the wonderbar. Regards,
  • Tom Merkel
    Re: Antenna cable conntinunity
    For the '67 antenna cable, be advised there is a capacitor in-circuit which will affect the ground readings. That is, it will appear as if there is an "open", i.e. lead in to ground. Check the antenna immediately below the antenna; look for a broken wire or open cap.
    Are you receiving any signal? AM and FM?
    Tom
