If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I replaced the front harness on my 57 several yrs. ago and am now thinking of replacing rear harness (?) does the rear harness connect on the drivers side down by kick panel and where does rear harness wind its way to the back including lt. and rt. tail area ,is it easy to route wiring any tips thanks
paul
I replaced my entire wiring harness on my 62.Not sure if there the same.But the connection for the rear harness on mine is on the drivers side kick panel area. The wires ran along the floor at the door under a plate. They came out near the end of the door.Ran up the edge of the opened door area toward the back of the seat.Into the convertable top storage area and through the the wall into the trunk.Then to the lights.
I believe it will be like the 53-55 which runs through the rocker panel, then through the fuel tank compartment before goinginto the trunk area and behind the spare carrier to the right side. A fair challenge to fish through all this.
Tie a string to the end of the old one before you pull it out. That string will become a "traveller." When you pull the old one out, the string will end up in the places the old harness used to be. Then tie the string to the new harness and pull the new harness through.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
