Hi Joe,
First...
Congratulations on receiving your NCRS Presidents Award. Your posts, knowledge, and opinions are priceless, and now that I have a picture, I hope I might run into you at Carlisle or some future NCRS event.
Second...
I read with great interest your April and July posts on disk brake caliper castings and have a couple of questions. I am trying to determine how "original" my old front calipers are, and whether they are worth rebuilding and putting back on my car. In a moment of haste, and poor advice, I regrettably replaced them recently with some later rebuilds from a local Corvette supplier, which I find "ugly" compared to my earlier castings (I have yet to turn in the cores). The replacements are not even black - they're grey. My late '65 convertible is a mostly correct restored driver that I wish to maintain as original as possible/practical.
The calipers I removed are very clean (and in my opinion pretty) first generation 5465954/5465952 castings which I will assume have been converted to second generation at some point in their lives since the pistons outwardly appear to be second design (no provision for insulators), so I'll assume the piston guides are long gone. There are some additional markings: (1) a large inverted "7" stamped above the casting number of each caliper half, and to the right of the casting number on each are, also inverted, respectively, the casting numbers 822, 118 (looks more like 811 right-side up), 258, and 8 (hard to tell if there were additional numbers after the 8 and filed off, or if there never were any others). What do these numbers mean? Are they date codes? Do they provide any indication as to whether these might be original to my car?
If these are not original to my car, are these first generation castings available from other rebuilders, so that I shouldn't worry about relinquishing these particular ones as cores? Or am I making altogether too much about these calipers, especially since they are not unmolested, but converted? My buddies with way more experience in the hobby just tell me to spray paint the replacements black and not to worry about it. Your input would be most appreciated.
As an aside, my rear calipers appear to be first generation, as well. How can I tell? What are the correct casting numbers?
Thanks.
Louis
First...
Second...
Thanks.
Louis
