C2 L79 Tach Cable - NCRS Discussion Boards
C2 L79 Tach Cable
  • frank clark
    C2 L79 Tach Cable
    The Cable for my Tachometer on my 66 L 79 broke as I was driving to work today. I have some questions.
    1. Can just the inner cable be replaced.
    2. Where is the best source to buy the parts I need?
    3. Lastly, The cable started making noise at the distributor end. I continued to drive the car an additional 350 miles or so before it broke. Are there other parts associated with the tach cable that may now be damaged?
    Frank
  • Jim T.
    • March 1, 1993
    • 5351
    Re: C2 L79 Tach Cable
    Frank I would not buy anything until you disconnect the tack cable at the distributor. Using a good thick steel putty knife or a tool like this to fit in the wide slot remove the tack gear and examine it. I suspect the gears will be broken. Lack of lubrication can cause this failure. If this is the problem you will need a new distributor shaft and tack gear.
