If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have a 1966 BB and have notice that my steering seems to be loosening. The wheel turns 1-2 inches before anything happens. Is this normal or a sign of something loose or worn?
Steering coupler and the steering box. Turn the steering shaft forward of the firewall while watching the output shaft of the steeing box. If you see extra play you may have found your culprit
Also check the pittman arm to center link joint. My car had a lot of play there until I adjusted the large set screw per the chassis service manual. You may also have to reset toe in when you're done
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
