1957 Starter shims - NCRS Discussion Boards
1957 Starter shims
  • Mike N.
    • April 1, 2001
    • 110
    1957 Starter shims
    On '57 Powerglide car- How does one know how many, if any at all, shims the starter takes???
    I remember spending a lot of time on my '75 trying to get the exact measurement because the starter kept on getting hung up when the car started. I fret having this problem with the '57 because I can't see the flywheel nor the starter gear.
    I bolted the starter on already without any shims.......it'll be a long time before I start the darn thing and I guess I'll just have to wait till then and see if it starts OK without the starter staying stuck to the flywheel.
    Any other suggestions would be greatly appreciated-
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1957 Starter shims
    You should have no problem because you don't shim a PG cast iron trans starter, they made them better back in the old days from a 75 vett.
    • Mike N.
      • April 1, 2001
      • 110
      Thanks ROY-
      Back in the day when I owned my first vette, a '58 fuelie, I used to change the starter all the time and never had to mess with the shims! I sure can't say the same for the '75-
      I feel a lot better now!
