DEAR SIRS:
I have a 1972 LT-1 that I am doing an engine restoration on. I am in need of the following information for the job: 1. Is there a air cleaner decal that goes on the the air cleaner and if yes what does it say and where is it placed on the the A/cleaner. also where can I get it. 2. Are there more than one a/cleaner decal on the ac or just one on a LT-1. 3. On the spark plug chrome shielding did the 72 lt-1 have the LH/RH front shielding, mine has the rear but not the front. 4. The support brackets that hold the ign. shielding box are chrome should they be painted red?or were they chrome in 1972?They attach to the manifold. 5.On the distributor there is no vaccum advance line connected should a vaccum hose be on it or no? 6.Under the Carb. there is an alum plate is this correct?
thanks
steve
thanks
steve
