what kind of lube should be used in my 63 manual steer box?service manual does not specify
63 steer box lube?
1052084 14.5 oz. tube
Chevrolet recommends a special lubricant for the Corvette manual recirculating ball steering gear. On source for the part number is my fifth edition Chevrolet Power Manual - 1052084, 14.5 oz. This product has a grease-like consistency. It is not a liquid like gear oil. This part number may have changed and Joe Lucia posted the current number (if it is, indeed, different) in a recent post. Recommend you check the archives.
Duke- Top
Re: 63 steer box lube?
The problem with using something other than a solid-type gearbox lube is that the steering mechanism gets hot enough from its proximity to your exhaust that any type of differential lube will tend to run out when it gets warm. GM does have their own lube, for which Uncle Joe and others can supply you with a part number. However, I have been very happy with standard grease gun style grease for over nine years with no harmful effects. I use the Mobil synthetic grease and one tube is plenty for your steering box as well as the grease fittings on the front suspension of the car. BTW, the GM lube numbers are in the Archives.- Top
On Target Once Again
Yes, the gentlemen who recommended the heavier, grease like lube for the gear box are absolutely correct. I tried a standard gear lube that a maintenance manual recommended and to this day I have a leaky steering gear box-the lube oil gets all over the splash pan underneath. It's a real mess. Next time I will try the standard grease option/14.5 oz lube as suggested.- Top
2084 14.5 oz. Tube Sources
My '57 steering box probably needs a rebuild, as it also leaks from the lower part of the cover. The 2084 14.5 oz. plastic tubes (NOS) are still available from 1) Vette Products in Clarkston, Michigan and 2) From Danchuk in California. Chassis grease is probably just as good.
John- Top
Re: 2084 14.5 oz. Tube Sources
Hey John, old buddy - I'm no expert on solid axle cars but I think your suspension and steering is basically a 1953 vintage passenger car design, and I don't even know if you have a recirculating ball steering gear, so the obsolete 1052084 and current 12377985 grease may not even apply to a C1. I guess we've spent so much time yaking about that "other car" I forgot to ask you the year of your Corvette. Now I know!
Duke- Top
