1973 BRAKE LINES - NCRS Discussion Boards
1973 BRAKE LINES
  • Wayne Roache'
    1973 BRAKE LINES
    Is it possible to replace ALL brake lines on a '73 with the body and motor in place?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1973 BRAKE LINES
    Wayne
    The short answer is yes but you need to do alot of bending and rebending. If you do it replace the rear brass blocks also. Lyle
    Lyle
    • Wayne Roache'
      Lyle,
      Thanks for your answer. I am going to give it a go in replacing the lines with the BRASS blocks.
      • Harmon C.
        • August 31, 1994
        • 3228
        Wayne
        Last time I needed the brass blocks my local GM dealer had the best price. Lyle
        Lyle
        • Lee S.
          • September 30, 2002
          • 156
          Re: 1973 Brake Lines
          I am also told this can be done. A friend did it on his '72 Coupe. He found that if the car was a minimum of 5 feet off the ground, bending was mimimal. So... do you have a friend with a hoist?
