There have been a few posts recently concerning the trim tag body build code on A-body cars, and how it sometimes lags dates on other St.Louis components.
The 1965 Judging Manual, 3rd edition, is quite clear on checking VIN and trim tags BEFORE judging commences, by comparing a table of month-end VIN #'s with trim date code for that month. The manual goes on to state: IF THERE ARE INCONSISTENCIES IN THE TRIM PLATE AND THE VIN PLATE, JUDGING WILL TERMINATE.
Mention is made, in the TAGS section of Operations Check, of the A-body build in Ionia Michigan, starting in Jan '64 (to end of '67 model year), but no guideline is given as to the acceptable lag due to A-bodies transit to St.Louis and subsequent holding while awaiting position on the vehicle assembly line. You can see what happens; at roughly 40 bodies/day production at each location, and (say) 10 days transit to St.Louis, the first 400 or so A-body cars off the final assembly line at the beginning of the month will bear a body build month code that doesn't correspond with the Judging Guide VIN table for that month. Example: used to own '65 # 16524 (off line 1st production day of May), yet the trim tag (A-body, coded I22 [April 22nd]). In fact, the first few days of a new month's production will also show 60 to 80 S-bodies produced the previous month, due to the one or two days lag from the time the trim tag is installed.
Perhaps not describing this lag in the guide is just an oversight. But, if the answer is that the judges do take this into account, then it would be nice to know what parameters they use to ensure consistency. Opinions welcome.
