tires - NCRS Discussion Boards
tires
  • Bill
    tires
    What are the widest tires, including aspect, that will fit on stock rallys for a '70 and still allow proper suspension travel and steering? Car currently has 225/70x15 which require replacement. Any recomendations on tire model?
  • Jerry Clark
    Re: tires
    Hi Bill:
    I have successfully run 255/60/15 on my 69 with no interference and little if any sidewall distortion. Everyone seems to like the new Michelin SX GT
    jerry
      Re: tires
      Bill-----
      The largest size that I know for sure will fit without interference or other fitment problems is 245-60-15. The other benefit of this size is that it is very close to the original F-70-15 size in diameter so speedometer calibration is essentially unaffected.
      I have heard of folks using the 255-60-15 size; some reporting slight interference problems and some not. Of course, 1978-82 Corvettes used the 255-60-15 size as an optional equipment tire. However, I believe that there were subtle changes made to the 1978-82 Corvette body work and/or inner fenders to accomodate this size tire and validate it for production use on a Corvette.
      I'm sure that aspect ratios lower than 60 would also enable the use of a wider tire without causing interference problems. However, I believe that such an issue is essentially moot since there are few, if any, suitable 15 inch tires manufactured with aspect ratios lower than 60.
