RESISTOR VOLTAGE C2 - NCRS Discussion Boards
RESISTOR VOLTAGE C2
  • Don 42616
    RESISTOR VOLTAGE C2
    With the ignition on & motor off I have 12.5 V at resistor useing red lead on my voltage meter to top lug on resistor & the black lead on the metal hood locks. With red lead on top & black lead on bottom lead it shows -3V. I assume the former lead position is correct? Don
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: RESISTOR VOLTAGE C2
    If I read your description correctly about where your "leads" were then you just checked the voltage drop across the resistor which is about 3 volts or 8-9 volts at the coil to ground.........
