C-3 1970 coupe BREAKS - NCRS Discussion Boards
  • Jack bogosian
    I noticed the break caliber on the bottom outside on the left side of my car is wet..The car pulls to the right when I hit the breaks and let go of the wheel any suggestion on the fixing of the caliber are the lines all metal?
  • Brian Monticello
    Re: C-3 1970 coupe BREAKS
    Jack,
    It sounds like your caliper is leaking. Contiminated pads have little stopping action and it takes very little brake fluid to contaminate a pad. You can send in your caliper for rebuild or rebuild it yourself. You might want to inspect all the other calipers while you're at it.
    Brian
    • Jack bogosian
      If I go with all stainless break lines and calibers is there a special vender or does corvette America have the same high quality parts.. Thanks
      • Warren F.
        • December 1, 1987
        • 1516
        Jack:
        Vette Brake Products will take your calipers and re-do or you can exchange them, your choice.
