TANK STICKERS - NCRS Discussion Boards
TANK STICKERS
  • TOMMY
    TANK STICKERS
    HI GUYS I HAVE A QUESTION THAT IS DRIVING ME CRAZY . THE QUESTION IS I AM IN THE PROCESS OF BUYING A 1967 427/400 CORVETTE, THE TANK STICKER WAS EMAILED TO ME AND IT LOOKS OLD AND STUFF LIKE THAT. IT HAS WRITTEN ON IT IN PEN OR PENCIL #405 IN THE LOWER RIGHT HAND SIDE!BUT I ALSO GOT EMAILED PICTURES OF THE CAR BEFORE RESTORATION OF THE CAR AND INSIDE THE 2 DOOR PANALS WRITTEN BY HAND IN MARKER 268 268 THE NUMBER 268 SHOWES UP SEVERAL TIMES ON THE CAR WHY ARE THE NUMERES DIFFRENT?????????????? PLEASE HELP..THANKS
  • Drew P.
    • June 30, 1977
    • 180
    Re: TANK STICKERS
    Hello Tommy,
    What is the VIN of the 1967 Corvette?
    Drew Papsun
    • TOMMY
      Re: TANK STICKERS
      I DONT KNOW . WOULD THAT CHANGE THINGS ? THANKS
      • Drew P.
        • June 30, 1977
        • 180
        Re: TANK STICKERS
        Hello Tommy,
        Yes, The VIN is key to all the numbers you listed. Contact the sell for the information.
        Drew Papsun
        • TOMMY
          Re: TANK STICKERS
          OK ,I SENT THE GUY A EMAIL TO GET BACK TO ME , DOES ANY OF THIS MAKE SENCE ?WHY TANK STICKER HAS A NUMBER AND INSIDE DOOR PANILS HAS DIFFRENT NUMBERS ? DO YOU HAVE A GUT FEELING ?
          • Roy S.
            Past National Judging Chairman & Concours Team ******
            • July 31, 1979
            • 1022
            Re: TANK STICKERS
            Tommy,
            The answer to your question is no the two numbers are not related.
              Re: TANK STICKERS
              Tommy -
              First, turn off your "Caps Lock" key - makes your post hard to read and implies that you're shouting.
              The car's pre-printed VIN didn't show up on tank stickers until sometime in 1971. Other hand-written numbers on it relate to the Body Shop Job Number (on some fiberglass body panels) and to the Final Assembly Sequence number (on the inside of the door trim panels, etc.), and neither of these will necessarily match the car's VIN.
              Comparing the "Expected Date Of Production" on the tank sticker against the car's final assembly date (derived from the VIN) is a better method of determining whether the tank sticker is really the one for that car.
              • TOMMY
                Re: TANK STICKERS
                the exp date of prod on sticker is 12/30/66 and the bild date is i think is E19 (dec 19 ??) ???
                • Dave S.
                  • August 31, 1992
                  • 2918
                  Re: TANK STICKERS
                  Tommy,
                  Al Grenning has taught us in his classroom sessions the the expected date of production is always a friday so be sure 12/30/66 is a friday.
                  • David W.
                    • December 1, 1999
                    • 272
                    Re: TANK STICKERS
                    It was.
                    • Stephen L.
                      • May 31, 1984
                      • 3148
                      Re: TANK STICKERS
                      The numbers in Chalk on the doors and body panels "268" were an internal job number for the initial body assembly before paint etc. This number typically appears on the passenger footarea of the firewall visible from outside the car, on each door internally, and on the rear outside bulkhead by the fuel tank.
                      The "405" on the tank sticker (usually written in the upper right quadrant next to the "trim" and "engine" lines,about 3/4" high) is a number that was assigned to the chassis assembly. On a '67 it typically is 1 or 2 numbers ahead of the actual final 3 numbers of the VIN. This number also repeated after 500 so it could mean that the VIN number will be either xxx406 OR xxx906 or possibly xxx407 or xxx907, if the sticker is for this car.
                      • Tom R.
                        • June 30, 1993
                        • 4081
                        Re: Point of Information...
                        My view differs on how we define the point at which VINs were preprinted on Corvette Order Copies or after 72, manifests.
                        VINs were not preprinted until Bowling Green Corvettes in 1981...all those that preceded were typed at the VIN tag station. The font is typically Time Roman...a business standard typestyle until after 78 when we see a bigger font that is non Times Roman...more like a Helvetica. Once BG cars are produced, we see manifests with the identical font style and impression as all other codes...or the OCRM font.
                        So my definition of preprinted is that the VIN is printed at the same time all other broadcast codes were printed rather than what was typed on the factory floor...after the manifest form was printed with broadcast codes.
                        Tom Russo
                        78 SA NCRS 5 Star Bowtie
                        78 Pace Car L82 M21
                        00 MY/TR/Conv
                        • Stephen L.
                          • May 31, 1984
                          • 3148
                          The VIN was NOT preprinted on the face of 67-72 CORVETTE ORDER COPY documents.
                          The last 3 digits of the "future" VIN numbers in increments of 500 numbers were handwritten on the ORDER COPY. These were typically within 2 digits ahead of the actual assigned VIN which was stamped on the frame prior to body drop.
                          Because this penciled number only went to 500; then if the VIN were XXX502 the penciled number would typically be "1" or "2" and so on.......
                          • Warren F.
                            • December 1, 1987
                            • 1516
                            Tom:
                            The Corvette Order Copy that is usually attached to the top of the fuel tank, during the '68 thru '72 models, contains information printed by a machine, its style of fonts is different than the partial vin that accompanies some of these documents, that style does indeed look to be typed.
                            • Warren F.
                              • December 1, 1987
                              • 1516
                              Steve:
                              A partial vin sequence of the car does indeed appear on some 1971 Corvette Order Copy sheets and on 1972 Corvettes as well.
                              We normally do not give the exact date of this change, as to not aid with those who would try to improve their forgery skills.
