If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Anyone ever heard of a process whereby your block pad stampings can be identified even though they not visibile to the naked eye (because the block has been decked for example). I have heard that law enforcement has a method for identifying stampings on guns even when they have been filed off and someone mentioned they thought this process has been applied to our hobby.
Thanks.
I have seen this process using acid on gun barrels when #s are filed off. Acid is applied & a image appears. I believe its because the stamped area is harder. But on a motor deck more is needed to authenticate originality. Weather broach mark would appear or not is ?.......But interesting ?? Don
Jack,
Even if the numbers could be raised, it would not be applicable to judging, I would not think. The appearance of the pad is the judged item and not necessarily what number was stamped there. Without the broach marks and the look of the number stamping, it would be pretty much usless. I would not think that any additional points would be awarded to any faint shadow of numbers that might be raised.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
