I recently had the opportunity to get my 66 small block L-79 350 HP up to 90 MPH +/- for a stretch while on a cruise-in with a group of Corvettes in our club. After I backed off I noticed the oil pressure gage was fluctuating up and down somewhere between 30 and 60. I stopped the engine checked oil level, which was almost to the full mark, restarted the engine and continued. If I hold the speed to around 70-75 I have constant oil pressure of 60. I had changed the oil and filter prior to this cruise. The same thing happened again while driving on the interstate and getting the speed up again fo a sustained period of time while passing.Once I back off on the speed and continue the pressure will remain steady again. I have not had this happen before.
I was wondering if the oil pump is the problem...possibly pumping more oil out of the crankjcase than can return to it....What say you experts out there??? What could be causing this.
