I purchased a set of brake lines for a 67 standard brake car from Corvette Stainless Steel Brakes in Miami, Fl. The hex fittings on the master cylinder to distribution block (front) are an orangey color, not yellow gold dichromate like the other hex fittings. On the master cylinder to distribution block rear line, one fitting is orange the other is a blue-green. The company tells me these are the correct colors. Are they?
The rear trailing arm lines have armour on them. I have read that 67 trailing arm lines DO NOT have armour on them.
Luke at CSSB was easy to deal with. He said he will give me what I want. All you NCRS judges out there--What do I want?
Ed
Ed
