Looking at a 66 Convertible a few hours away, owner says was originally a 427/425 BB car but now has a 327 in it. He bought it that way. Trim tag codes match color and trim on the car now. Below is the evidence he claims causes it to be an original BB car:
"Correct rear end/half shafts, rear sway bar, thicker front sway bar, 427 emblem holes, Transistor ignition holes, correct radiator support and fan shroud (cut to accomodate the 327), 80lb oil pressure gauge, and 6500 rpm tach. Also has holes for BB left side hood support."
What else could be easily checked to validate the BB claim? How far should I go to try and validate this claim that would prove the BB status to most reasonable folks? I'm interested in the car, but only if I it is originally a 427/425. Thanks for any info/input in advance!
