I have purchased a GM screw in rocker stud kit and am ready to machine my SB heads to accept the studs. It looks like the stud bosses need to be machined down by about the thickness of the hex on the screw in studs. Is this correct?
Machining SB heads for rocker studs
Re: Machining SB heads for rocker studs
measure the screw in stud length from under the hex to the top of the stud,add the thickness of the guide plate, set the end mill at the top of one of the orignal studs in the head,lower the mill head or raise the table the distace you measured from the screw in stud plus the guide plate thickness and you are there. you want the top of the screw in stud to be at the same dimentional location as the orignal pressed in stud. of course you will need to remove the press in studs after you take the measurement before cutting- Top
