Can not seem to locate it. Thanks Larry
Where is date on1967 hardtop plexiglass??
Re: Where is date on1967 hardtop plexiglass??
If you can find the stamp but no date, there probably isn't one. If you can't find the stamping, the positioning wasn't always perfect either.
Try looking near or under the weather stripping around the lower left rear corner. It could be faint, or partially hidden.
H. a. N. D.- Top
As I recall, the date code consists of a letter to the upper right of the logo and another letter to the lower left. The TIM&JG should have the details.
On my original 67 window, only the upper right letter appears. I'm aware of at least one other 67 hardtop with the same situation. I've heard that the date coding was not always done correctly by the manufacturer.- Top
