C2 sun visor screws - NCRS Discussion Boards
C2 sun visor screws
  • Don 42616
    C2 sun visor screws
    Can someone clear up ? on correct fasteners for attaching/tightening visor on support rod.? Paragon catalog pg. 107 shows kit 4 screws + 4 nuts. I thought the double sided slot screw was correct.(I know I have to alter a screwdriver to fit).. If so where can I order some of interlocking screws? I tried the all the catalogs, Could not find them. Regards, Don
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C2 sun visor screws
    Paragon or Corvette Central should have what you need.
    • Gerard F.
      • June 30, 2004
      • 3803
      Don,
      I think what you are calling a double sided slot screw, at least the female portion, is what Paragon calls a special nut. The special nut is what you need the altered screwdriver to tighten. You could also use a tack puller or a mini wonderbar nail puller, instead of the altered screwdriver, to tighten the special nut.
      Jerry Fuccillo
      #42179
      Jerry Fuccillo
      • Jack W.
        • August 31, 2000
        • 358
        mini wonder bar nail puller - is that what I and my pals in the roofing - carpentry trades call a "cats paw"?
        • Don 42616
          Thank you Gerald. Explanation noted. *NM*
          • Gerard F.
            • June 30, 2004
            • 3803
            Jack,
            Similar, but with a flat paw, like used for carpet or upholstery tacks. The notch spans the hole for the screw, and the wedge engages the slots in the special nut. Boy, are we getting technical here!
            Jerry Fuccillo
            Jerry Fuccillo
